Quote Originally Posted by optic View Post
Thanks for the above info.
Looks like im i strife as the head size is 16 or 17mm square, bolt dia 10mm.
I do recall that they were square headed bolts in this winch which i have had for a long time.
Near enough to 20 years i would think.
Ill get some 10mm bolts and rebuild the head to suit the T slot.
The other concern i have is, i had this winch mounted to the inside of an 8 inch channel bull bar home made and never bent, trees and all.
It was that heavy i had to up grade the springs in the gutlux.
The winch was mounted against the inside of the channel and a direct pull against the T bolts.
So the forces were in a straight line against the mounting housing.
It is now going to be mounted 90 deg to the mounting points in the cradle.
My concern is will it break under strain as the mounting brackets are only ally?
I would hate to find out the hard way in the middle of no where.
In any case thanks for the above info.
Cheers.
Are these the bolts you're after???
http://www.ebay.com.au/itm/Warn-8274...8AAOSwbYZXa9JP
