Thanks Darren. That's helpful. Have had a brief read through. I'll check out access with the bullbar when my back allows.
It does appear that it would just need the gears cleaning & re-greasing, as I imagine it has done very little work during it's life & the grease has probably gone hard. The brake mechanism & motor shouldn't need touching. The main issue for me (if there is one) will, I think, be getting the winch off & back on to the vehicle.
You could throw a rope around each end and tie it up with the rope out the top. Unbolt it and the ripe will take the weight. Unbolt it and lower it down.
Even if you get it off and serviced, lining someone up to give you a lift back in will be simple enough. Does it have wire rope or synthetic rope? Un spool the wire rope and remove before you take the winch off will strip half its weight.
