Results 1 to 10 of 76
Thread: Coolant is still running too cold?
Threaded View
    Quote Originally Posted by Throbbinhood View Post
    Is the sensor getting enough flow where it is mounted? Mine is just one of those adapters, cut a section of the top hose out, put adapter in, screw the gauge into that.
    FWIW. My rb30 takes forever to warm up. Just idling, even for ten minutes, only gets the temp up to 65-70. It did it with two thermostats I've had in it. A 5-10minute drive gets it up to temp pretty quick though, don't rely on just idling it to get it to temp.
    Yours would take even longer as it's losing temperature to the gas converter as well.
    Same here my patrol takes ages to get to temperature Id say a good 10-15 Kays
    @dom14 you need to bleed the air from that hose on the condenser,
  2. The Following User Says Thank You to threedogs For This Useful Post:
    dom14 (17th August 2016)
