Results 1 to 10 of 76
Thread: Coolant is still running too cold?
Threaded View
    Legendary dom14's Avatar
    38 Post(s)
    I find it to have any sensor as close as possible to the original the most practicable and efficient way of getting the correct reading.
    Don't know how different your engine is to mine (tb45), but I've got mine just before the thermostat right next to the original one.
    Sent from my XT1068 using Tapatalk
    Stock temperature sensor is on the coolant out port on the cylinder head as in below picture.
    Today, I extended the aftermarket sensor wire and fitted the sensor right next to the stock one.
    Extending the sensor wire didn't upset the temperature reading accuracy that much. About three quarters of
    a degree lower than the reading before, so it's ok.
    I ran the engine for about ten minutes on idle and temperature didn't go above 63 degrees.
    So, it's even worse than the readings I've got before from the T joints of the heater core/LPG converter.
    I'm assuming the the thermostat hasn't opened up. So, I'm gonna take the vehicle for a drive tonight and see how it goes.
    I'll post the outcome.
    If the temperature is still low, then my last temp sensor installation spot is inside the thermostat housing.
    If the temperature reading is still low, then I think I would have to say the engine's running bit cold, either due to
    thermostat opening up too early or water somehow leaking through the thermostat opening valve/housing.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
