If you're running for 10 minutes on idle and only getting a maximum of 63 degrees I think the thermostat is stuck open. It only needs to be a little bit. Mine was stuck open by 1-2 mm and that was enough for my temps to stay quite low.
I've never seen a sensor installed in the actual hose like that before don't know if it makes a difference or not to the temperature.
Sent from my XT1068 using Tapatalk
