@MudRunnerTD
Well 4" and very busy but you got thru. Did you only dry clamp(no sealants)?
Reason for 4" (hot/cold side) in lieu of say 2.5" (hot side)/ 3"(cold side)? Propose to use 2.5" hot/cold side.
Came across @AB FMIC install (post 14) and read re: compression (ref @nissannewby) :
http://www.nissanpatrol.com.au/forum...l=1#post501187
With retaining vertical spt brkt (slightly modified), positioned cooler fwd, did the silicon joiner cause the need to flip cooler to provide clearance to bar mount brkt?
