Results 1 to 10 of 30
Thread: EDS engine data scan vs Scanguage II
Threaded View
  1. #23
    Aug 2015
    Cairns
    My experience with the EDS:
    After the initial install I didn't bother to do all the set ups immediately and all appeared to work well....
    After making all the basic settings, date, time, engine size, fuel tank size, fuel type and cost I noticed that the Trip meter was no longer working, this includes the instant fuel consumption display.
    So I reset the device and all was once again in order. Settings once again adjusted as above and again trip display showed *NOT SUPPORTED*
    I then went through each setting one at a time and have found that by not setting the fuel type the trip function continues to work. I have also not setup the fuel cost function as yet but it does seem to be working.
    There is an adjustment for Fuel Cut Off which is apparently variable for different makes of car and changes how the fuel consumption displays. However, there is no information given on how this adjustment affects the accuracy or what setting is suitable for which vehicle. At present with the default setting the instantaneous consumption shows a reading I think is plausible but when running against compression with the throttle closed the consumption increases. I will be fiddling around some more to see what happens.
  2. The Following User Says Thank You to GUDriver For This Useful Post:
    neilo99 (24th February 2018)
