I priced around looking for recovery points, ARB were selling ones similiar to what I bought for $110. Went to a metal fabricator who quoted $200 to make a similar plate, the one I bought was from outback ideas and cost $55, So I thought it was a good deal.
Cheers Mick
Everyone makes mistakes, the trick is to make them when no-one is looking.
NO they don't have any stamps, but was told by both ARB and OL that they would easily hold 10T. Outback ideas appear to be the main manufacturer of these plates. The metal fabricator that I had a chat with said that they would hold well over 10000kg, but he wanted $200 for each point.
Cheers Mick
I don't think any of the aftermarket recovery points are load rated as Mick has found so far, so it's just a matter of installing the strongest and safest recovery points available so they are not the weak link in a recovery. If it can't be made legal at least make safe.
Tony
The only rated recovery/tow hook found was at Supercheap, 4.5t and cost $30.00, plus I would have to drill holes in chasis to fit. Was only held on by two bolts and had a retainer clip to hold your recovery equipment in place. I was not keen on this idea, especially if the trol is belly deep in mud, that type of point just wont cut it.
Cheers Mick
I think you will find most of the aftermarket recovery points are drilled to accept the the type of rated hooks you saw at Superthief.
Tony
my mate peter from all terrain 4x4 custom makes is own rated recovery points mate, best on the market, should give him a call 03 9532 5558 cheers
THERES NO SUBSTITUTE FOR CUBIC INCHES
