Page 41 of 212 FirstFirst ... 3940414243 ... LastLast
Results 401 to 410 of 2116
Thread: Merged - Deleted "Wanted"
  1. #401
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Quote Originally Posted by the ferret View Post
    What I want to know, is why does it cost $90 for a piece of 10mm plate with a few holes in it, even 12mm plate , plus 3 hi-tensile bolts.
    I could easily make a similar plate, even thicker and out of bizoloy for probably $10 max in material cost, plus say $15 worth of bolts and washers.
    Are these "bought" ones tested and stamped with a load rating?
    No, I don't make them, and not trying to drum up work, but I tell ya what, I'm thinking of it!!
    Go for it ferret - I'll take two fronts mounts thanks!! I agree mate - seems a lot of coin for some smallish pieces of metal - and for that money, they'd want to have a load rating stamped on them!!
  2. #402
    Oct 2010
    I priced around looking for recovery points, ARB were selling ones similiar to what I bought for $110. Went to a metal fabricator who quoted $200 to make a similar plate, the one I bought was from outback ideas and cost $55, So I thought it was a good deal.
    Cheers Mick
    Everyone makes mistakes, the trick is to make them when no-one is looking.
  3. #403
    Quote Originally Posted by molongmick View Post
    Are any of the recovery points that you looked at load rated and stamped?
    Tony
  4. #404
    Oct 2010
    Quote Originally Posted by YNOT View Post
    Tony
    NO they don't have any stamps, but was told by both ARB and OL that they would easily hold 10T. Outback ideas appear to be the main manufacturer of these plates. The metal fabricator that I had a chat with said that they would hold well over 10000kg, but he wanted $200 for each point.
    Cheers Mick
  5. #405
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    Quote Originally Posted by Bigrig View Post
    Sorry Bigrig, can't help you atm, I would need quite a few orders to be able to organise the laser cutter to cut a heap and be able to offer them at a fair price.
    If there is a fair bit of interest, I would have a hundred cut at a time.
    Cheers Rod.
  6. #406
    Oct 2010
    I hear you boss and not having a shot, but what they "tell you" won't stand up in court! They need to be load rated and stamped.
  7. #407
    I don't think any of the aftermarket recovery points are load rated as Mick has found so far, so it's just a matter of installing the strongest and safest recovery points available so they are not the weak link in a recovery. If it can't be made legal at least make safe.
    Tony
  8. #408
    Oct 2010
    The only rated recovery/tow hook found was at Supercheap, 4.5t and cost $30.00, plus I would have to drill holes in chasis to fit. Was only held on by two bolts and had a retainer clip to hold your recovery equipment in place. I was not keen on this idea, especially if the trol is belly deep in mud, that type of point just wont cut it.
    Cheers Mick
  9. #409
    I think you will find most of the aftermarket recovery points are drilled to accept the the type of rated hooks you saw at Superthief.
    Tony
  10. #410
    Advanced blake_gq4.2's Avatar
    Mar 2011
    Bendigo vic
    my mate peter from all terrain 4x4 custom makes is own rated recovery points mate, best on the market, should give him a call 03 9532 5558 cheers
    THERES NO SUBSTITUTE FOR CUBIC INCHES
