Happy days, glad you've found the problem. If you still have the manifold off now is a good time to check you don't have a leaking oil cooler/blanking plate (which ever is fitted). Doesn't use a gasket, just silicone, but a pain in the backside to change if the manifold is fitted. Located between the starter motor and the intake on the block.
