Hey guys having some problems with my tb42 at the moment. It seems cyl 1 and 2 are either not firing properly or completely out of time as when I pull the leads off the engine idle doesnt change at all. I've replaced leads and plugs, it already has a gt40r coil and a pirahna elect ignition and extended rotor button, set timing to about 14 but if cyl 1 isnt firing right I would assume this would completely fk up the timing? I have also checked and re-gapped the tappets the other night (they were out a bit but nothing extreme) and also cranked the engine over too make sure there wasnt any valves sticking. While checking the tappets I noticed a little bit (not alot at all) of coolant in the rocker cover which lead me to assume head gasket/head. So just now before writing this, I checked the compression of all cylinders and the results were 135-145, so not alot of difference. Also I have leaned the auto choke off as much as I could and have removed the noise suppressor. The strange thing though is when cold the idle is shit house (assuming because of the auto choke but whatever) and when warm it idles pretty nicely. When driving it until about 2500 rpm it runs like crap but after that it pulls like a train, almost like its running on 6 then.
I am completely lost as what to do right now so any suggestions would be great, I'll start with the simple things simply because no one wants to spend money where it is not needed
