Results 1 to 6 of 6
Thread: TD42 Water Pump & Timing Cover Coolant Leak Cost
Threaded View
  1. #6
    Quote Originally Posted by Sofes View Post
    Maybe, just maybe I am haha.
    Was only going to remove it to either body swap the engine or make it cheaper to do.
    Just a look through your thread Winnie, how long did it end up taking you?
    I got told you had to remove the IP to get the timing backplate off?
    You can leave it bolted to the engine which means you do not have to re-time it.
    As for time I'm not really sure as I spent an hour here and there on it over a fair time. If you have all the tools and are more prepared than I was you can certainly do it in a weekend.
    Sofes (9th May 2019)
