I got one for free from a mate... No vac or oil fitting with it, it's just the pumpYeah it does, the hose I have is a pre-bent rubber hose which used to go to the sump but it won't work with the block drain. I'll just get something a bit more flexible that won't kink.
Good score mate!
That's perfect!
Why do you want to relocate though?
If I was you I would get a new o ring, install pump and block vac outlet for now and use old alternator vac and later on run a line or magically find oem line for double vac. I'm running double vac and it's definitely a bonus!
Can never have too much vacuum!
