Page 108 of 116 FirstFirst ... 106107108109110 ... LastLast
Results 1,071 to 1,080 of 1157
Thread: Winnies 747 TD42 GQ
  1. #1071
    Tek-Screw Gun ;-)
    Bring it!!
    Sorry Daz :-)
  2. The Following 2 Users Say Thank You to MB For This Useful Post:
    AB (31st October 2018), Winnie (31st October 2018)
  3. #1072
    Did you buy a vac pump Winnie?
    Didn't come with the vac feed to other side?
  4. #1073
    Block has oil drain fitting yeah?
  5. #1074
    Tek-Screw Gun ;-)
    Bring it!!
    Sorry Daz :-)
    Too soon..... farker
  6. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (31st October 2018), MB (31st October 2018), Rossco (31st October 2018)
  7. #1075
    I got one for free from a mate... No vac or oil fitting with it, it's just the pump
    Yeah it does, the hose I have is a pre-bent rubber hose which used to go to the sump but it won't work with the block drain. I'll just get something a bit more flexible that won't kink.
  8. #1076
    Just need to confirm a couple of things...
    This is the oil feed port for the turbo?
    The blue circle is the water feed for turbo? My old setup used the red circle.
  9. #1077
    I got one for free from a mate... No vac or oil fitting with it, it's just the pumpYeah it does, the hose I have is a pre-bent rubber hose which used to go to the sump but it won't work with the block drain. I'll just get something a bit more flexible that won't kink.
    Good score mate!
    That's perfect!
    Why do you want to relocate though?
    If I was you I would get a new o ring, install pump and block vac outlet for now and use old alternator vac and later on run a line or magically find oem line for double vac. I'm running double vac and it's definitely a bonus!
    Can never have too much vacuum!
  10. #1078
    All above correct, I assume blue circle is correct but I just used red circle as my old turbo set up coolant feed line was there and it made sense to keep it rather than new line.
  11. The Following User Says Thank You to AB For This Useful Post:
  12. #1079
    Good score mate!
    That's perfect!
    Yeah I've got the o rings, I'm gonna install the pump and have both vac pumps running into the canister on the drivers side.
    Gonna be very easy to run a vac hose from the timing case mounted pump there, and there are already solid vac hoses going across the firewall so I will just go from the alternator to one of those solid hoses and from the other end of that to the canister.
    Darren reckons he also had a good improvement just from moving the canister over.
  13. #1080
    Exactly what I was hoping to hear lol. I will just need to get a plug for the blue circle.
  14. The Following User Says Thank You to Winnie For This Useful Post:
