Page 7 of 35 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 341
Thread: Fund Raiser AB blew his engine
  1. #61
    Patrol Freak Sherro's Avatar
    Feb 2014
    Logan, QLD
    Gave what i could best of luck AB great mob here to get you going again.
  2. The Following 2 Users Say Thank You to Sherro For This Useful Post:
    MudRunnerTD (25th September 2016), Woof (25th September 2016)
  3. #62
    Thanks guys, feeling the love!!!
    So far it looks like I've hydro locked the engine from a brand new turbo failure but I need to confirm this.
    Sump is off and the crank looks perfect, in fact my whole engine looks perfect apart from a catastrophic number 2 piston conrod bent/smashed and has destroyed my block and god knows what else on the top.
    I'll pull it apart to confirm the above and take the next step but again, such a huge shame on a beautiful engine.
    I searched for 6 months to find this purely for the condition the engine and drivetrain was. Devo!
  4. The Following 7 Users Say Thank You to AB For This Useful Post:
    growler2058 (25th September 2016), mudski (25th September 2016), Rossco (25th September 2016), Sherro (25th September 2016), Sir Roofy (25th September 2016), threedogs (26th September 2016), Woof (25th September 2016)
  5. #63
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Is it possible to get some compensation from the turbo supplier?
    >>>tappin from tassie
    Hello from Under Down Under!
  6. The Following User Says Thank You to taslucas For This Useful Post:
  7. #64
    Is it possible to get some compensation from the turbo supplier? >>>tappin from tassie
    Hard road unfortunately mate, I need this engine out and 100% confirm crank is fine first and then prove the oil contamination locked it up.
  8. The Following 2 Users Say Thank You to AB For This Useful Post:
    growler2058 (25th September 2016), Woof (26th September 2016)
  9. #65
    22 Post(s)
    I wouldn't reuse the crank anyway, a local bloke up here hydro'd his motor (cyl 1) rebuilt and turbo'd, then snapped the crank at #1
    At the very least it needs to be crack tested, dont just do a visual
    96 GQ coil/Cab
    08 G6eT
  10. The Following 3 Users Say Thank You to Ben-e-boy For This Useful Post:
    BigRAWesty (25th September 2016), growler2058 (25th September 2016), threedogs (26th September 2016)
  11. #66
    I wouldn't reuse the crank anyway, a local bloke up here hydro'd his motor (cyl 1) rebuilt and turbo'd, then snapped the crank at #1 At the very least it needs to be crack tested, dont just do a visual
    Hey mate, yeah I wasn't intending on using it again, just to see if crank is fine then the issue was #2 alone.
    More so what and how this happened.
  12. #67
    22 Post(s)
    Cyl 5 is the next to hit tdc.. generally speaking hydro lock usually only effects 1 cylinder.
    96 GQ coil/Cab
    08 G6eT
  13. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    AB (25th September 2016)
  14. #68
    Sorry mate the mystery continues. Just went down again and no joy.
    The bungalow is a mess, was she in there?
    All good mate. It'll turn up one day..
    Somewhere.
    Maybe..
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    @MudRunnerTD done son! Shout out if there's more required toward the end of the fund raising, will do what I can. Chin up AB!
  16. The Following User Says Thank You to Touses For This Useful Post:
    MudRunnerTD (26th September 2016)
  17. #70
    Oct 2010
    Old Bar, NSW
    @MudRunnerTD
    Done what I can, Still getting over what we helped Roofy out with, then didn't get to travel with him LOL
    Serious though I have been fortunate with our recent insurance claims, so a bit of paying it forward, back, up, sideways whatever is good karma.
    Good luck with it all AB and now I'm no longer gainfully employed I might sneak south for the party and try one of your pizza's if that's OK?
    Macca
  18. The Following 4 Users Say Thank You to macca For This Useful Post:
    BigRAWesty (26th September 2016), MudRunnerTD (26th September 2016), Rossco (26th September 2016), Woof (26th September 2016)
