Maybe your thermostat is sticking open.
The aftermarket temp sensor needs to be as close to the heat as you can get it for an accurate reading.
When I have had temp readings like your pic is showing,
Replacing the thermostat cured it, each time.
IF IT'S NOT A NISSAN.
THEN IT'S A COMPROMISE
dom14 (16th August 2016)
