Results 1 to 10 of 76
Thread: Coolant is still running too cold?
Threaded View
  1. #5
    Jul 2016
    put the sensor in the correct place and extend the wire to reach. You may need to install a genuine thermostate or at least the correct temperature range. To cold means more fuel will be used. As the ECU will think the engine is cold and needs more fuel. Been there done that.
  2. The Following User Says Thank You to kbchez For This Useful Post:
    dom14 (14th August 2016)
