Page 48 of 212 FirstFirst ... 4647484950 ... LastLast
Results 471 to 480 of 2116
Thread: Merged - Deleted "Wanted"
  1. #471
    Legendary big_fletch's Avatar
    Oct 2010
    Tatura VIC
    Quote Originally Posted by gazoo View Post
    HI thanks silver for your info but yea i been their done that. all u have to do is tap the starter with a small hammer and away it goes so its on the blink and cant get ity done befor easter so now i guess i stay home this year o well their is another times
    Giving the starter a small tap usually means that its about out of brushes on the armature..
    Not sure on the price of a new one however they can sometimes be rebuilt for a lot less than a new one..
    Maybe something to consider?
    Qualified Auto-Electrician
    Apprentice Sparky
    Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
  2. #472
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by big_fletch View Post
    Agree If the brushes are serviceable externally it is a very simple task to replace ive done em on old Ford 302 windsor motors i think they were lucas starters would pay to check it out
  3. #473
    Oct 2010
    Tatura VIC
    Quote Originally Posted by growlers71gq View Post
    You are on the money mate, the old Lucas and Bosch starters were brilliant and very cheap to repair lol..
    Definitely worth looking into a rebuild for the troll though
    Apprentice Sparky
  4. #474
    Feb 2011
    Shed
    45 Post(s)
    What breed are the starters on the troll td42
  5. #475
    Oct 2010
    Tatura VIC
    Not 100% but I think some were Bosch, might check it out tommorrow and have a look see I thinks
    Apprentice Sparky
  6. #476
    Feb 2011
    Brisvegas
    tap solution often = dodgy solenoid. You can by pass the solenoid in a range of ways, including suitable electrical cable and momentary on switch in cabin
  7. #477
    Oct 2010
    Tatura VIC
    Quote Originally Posted by Silver View Post
    That is sometimes true, however majority of the time the starter is out of brushes.. If you had a test light or set of multimeters on the output of the solenoid you would most likely find there is power coming out, however because the brushes are worn in the starter there would be a bad connection to the armature. Therefore the solenoid would click out however starter would not spin.. Giving the starter a tap moves the brushes ever so slightly and sometimes creates a good enough connection to spin the armature..
    The best option is to remove the starter and take to a auto-sparky to be diss-assembled and tested for the best course of action
    Fletcha
    Apprentice Sparky
  8. The Following User Says Thank You to big_fletch For This Useful Post:
    Silver (20th April 2011)
  9. #478
    Hitachi.
    Found one at recycle centre for $5.00. After purchasing a brand new one.
    rebuild can cost around $400
    Ensure a reputable re-issue. +$750.00.
  10. #479
    Feb 2011
    Brisvegas
    Fletcha
    agreed, however if the solenoid is by-passed, without a tap (gotta love percussive maintenance :-) ) and the starter spins, to me that points to the solenoid.
    By-passing the solenoid can somtimes be done with a big screwdriver you don't care too much about as sparks will be produced - in by passing, looking to momentarily connect the fat positive wire that goes into the solenoid to the fat wire that leaves the solenoid and goes to the starter. Either way, some time on the spanners will be required down the track. What I was looking for was a possible solution that would get Ga200 back on the road over Easter :-) Of course, if it is a manual, use the family starter motor and or convenient hills :-)
  11. #480
    Feb 2011
    Brisvegas
    Quote Originally Posted by trollman View Post
    Hitachi.
    did you buy it? :-)
