Qualified Auto-Electrician
Apprentice Sparky
Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
IF YA DONT GET STUCK YA AINT TRYIN HARD ENOUGH........OR YA TOOK THE CHICKEN TRACK![]()
Apprentice Sparky
Not 100% but I think some were Bosch, might check it out tommorrow and have a look see I thinks
Apprentice Sparky
tap solution often = dodgy solenoid. You can by pass the solenoid in a range of ways, including suitable electrical cable and momentary on switch in cabin
That is sometimes true, however majority of the time the starter is out of brushes.. If you had a test light or set of multimeters on the output of the solenoid you would most likely find there is power coming out, however because the brushes are worn in the starter there would be a bad connection to the armature. Therefore the solenoid would click out however starter would not spin.. Giving the starter a tap moves the brushes ever so slightly and sometimes creates a good enough connection to spin the armature..
The best option is to remove the starter and take to a auto-sparky to be diss-assembled and tested for the best course of action
Fletcha
Apprentice Sparky
Silver (20th April 2011)
Hitachi.
Found one at recycle centre for $5.00. After purchasing a brand new one.
rebuild can cost around $400
Ensure a reputable re-issue. +$750.00.
agreed, however if the solenoid is by-passed, without a tap (gotta love percussive maintenance :-) ) and the starter spins, to me that points to the solenoid.
By-passing the solenoid can somtimes be done with a big screwdriver you don't care too much about as sparks will be produced - in by passing, looking to momentarily connect the fat positive wire that goes into the solenoid to the fat wire that leaves the solenoid and goes to the starter. Either way, some time on the spanners will be required down the track. What I was looking for was a possible solution that would get Ga200 back on the road over Easter :-) Of course, if it is a manual, use the family starter motor and or convenient hills :-)
