Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 71
Thread: Possible clutch damage after towing
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    I find the heavier the trailer/caravan, more control I have with reversing. I find it bit a of PITA to reverse the lightweight trailer without any weight on it. When the trailer is heavy, it seems to be doing what I'm asking it to do. When the trailer is lightweight, I had to yell at it.
    The longer the distance from the drawbar to the wheels, the easier it is to reverse, as it is slightly less sensitive. The weight shouldn't make a difference, although a load in a box trailer makes it easier to see.
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
  2. #12
    Legendary dom14's Avatar
    38 Post(s)
    were you riding the clutch that much,
    I used to put it Low low in my other 4x4 to park my camper more control I felt
    Lucky I have an auto now so dont worry about it
    RB30 hasn't got that much power, so I had to give a bit of revs to get it going over the curb(both the 4Wd and the van).
    I reckon with the high revs of the RB30, standard clutch tend to wear out quicker.
    I think it lasted this long without any major dramas 'cos of my gentle kind of driving.
    But, I wasn't that gentle to get the van into the middle of the driveway at pitch dark night.
    What I should've done was to put on 4Wd. I didn't 'cos steering is bit rough on 4Wd.
    At least I get to know the clutch better now. They obviously don't last forever.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  3. #13
    You only put it in low ratio,, you dont lock in the hubs etc.,,,but whats done is done eh
    Does it drive OK on the road
  4. #14
    Patrol God Stropp's Avatar
    38 Post(s)
    Hi mate, If I understood you correctly, you want me to park back(or front) of the car against a tree or a wall or something and then let it go and see whether it stalls.
    Am I right?
    correct mate easy way to see if the the clutch is fubar
  5. #15
    38 Post(s)
    the smell my be the the rear main seal has gone and leaked a bit of oil onto the clutch and thats why it slipped ??
  6. #16
    38 Post(s)
    Thanks for the tip mate. I'll have a good look under the car to see whether I can see any oil drips. Oil level was ok when I checked while ago, I'll check it again. I rarely check clutch oil, 'cos it never dropped. It may not be the case now.
    Cheetah Outreach
  7. #17
    38 Post(s)
    Yes, it drives ok on the road without clutch slipping(not heavy trailer or caravan). Even with the van it would go ok when moving forward.
    Reversing tend to aggravate the clutch or something and gives out that strange smell, which isn't exactly the clutch burning smell(I"m used to the clutch burning smell)
    Sorry mate, I didn't understand that first bit. It's manual locking hub. I can't engage the front wheel drive without moving the hub lock knob to lock position(in the middle of the front wheels), or can I?
    Without engaging the hub lock, the front CVs would just spin themselves without spinning wheels, won't they? Correct me if I'm wrong.
    It also says in the 4WD engage guide(sticker on the sun visor) that I need to lock the hubs first before switching to 4WD. I've been told not doing so can damage the hub or CVs or something like that. I'm not sure if that's correct.
    Cheetah Outreach
  8. #18
    Mar 2013
    NE Melbourne
    Hi dom14, I don't think reversing in low range with the hubs unlocked will damage anything. I do it all the time! I doubt there will be any uncontrolled spinning of front diff as the transfer case splits power 50:50 on both ends so if rears aren't spinning it will be constant power to the front. You also won't be revving the guts out of it either.
    Do you know what type of flywheel your Patrol has? The symptoms you described sound like a dual mass flywheel that's leaking oil from the buffers onto the clutch. Happened to a friend a few years ago (GU 3.0 litre). No drive and burnt smell yet the engine was fine. If no DMF then maybe the rear oil seal as suggested previously.
  9. The Following User Says Thank You to Rock Trol For This Useful Post:
    dom14 (15th April 2015)
  10. #19
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    you can engage the transfer lever in the cab, from 2 wheel drive to low range
    just DONT touch the hubs - leave them free wheeling
    your wanting to use the low torque and gearing of the transfer case to assist you in reversing it up your driveway
    NEVER NEVER NEVER lock your hubs in & engage 4wd while on Bitumen / pavers / slabs / any hard surface
    guaranteed to spit the teeth out of your transfer case if you do.......... (speaking from experience)
  11. The Following User Says Thank You to Bigcol For This Useful Post:
  12. #20
    38 Post(s)
    Quote Originally Posted by Bigcol View Post
    Crxp! I'v done it in the past, just to test the 4WD and I've even done 40km/h on bitumen like that.
    Ok, it's obvious I have a fair bit to learn about 4WD'ing with GQ Patrols.
    Cheetah Outreach
