Hi Guys,
Mine is a RB30 manual Patrol on carby.
The other day, I had to move my small caravan from one spot to the other.
Van is a 11 foot fairly lightweight one. I only added about extra 20 to 30kg recently by doing some floor repair.
When I was towing forward, it went ok
But, when I was backing up to the driveway, I started smelling a "funny" smell coming from the engine bay.
It's similar to the burning clutch smell, but may be slightly different.(burning clutch+brake oil ?!)
Smell was still there in the engine bay even a day after.
As you guys might know, clutch pedal is hydraulic.
I've never had to do anything with the clutch for about five years now.
I'm wondering whether I've done some clutch damage.
The reason for that is that I'm feeling the clutch differently now.
When backing up, vehicle tend to shake more as it's from a rough clutch.
Going forward isn't that bad, but it tend to do the same thing occasionally, but less aggressive.
1)Have I done some clutch damage?
2)How do I find out if the clutch's on it's way?
3)What tests can I do to confirm the clutch is up to scratch with towing the van
BTW, when I was backing up the van, it wasn't a steep climb. It was fairly flat ground, except I had to go over four or five inches of
the curb to push the van into the driveway. I did the backing up on two wheels. I didn't think 4WD was necessary at that time.
Thanks for any help guys.
