Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: EGT reaching 600+
    Expert Patrol-Guy's Avatar
    Dec 2013
    NSW
    what boost are you getting at 100 Kph ?
    Not real sure but I think about 8/10psi.
  2. #12
    Quote Originally Posted by Patrol-Guy View Post
    I've done the Dawes needle and catch can but the mechanic couldn't clear the chech engine light and so pulled out the EGR plate.
    Putting the plate back in will lower your EGT's.... Or drill an 8mm hole in the guts of the plate. This will equalise the pressure in the EGR valve and making the ECU think its working. While your not totally blocking the EGR, you will be slowing it down a lot still.
    Time for a bigger intercooler and better bonnet scoop. This combo will certainly help.
  3. #13
    Patrol Freak kevin07's Avatar
    georges hall
    definitely do the exhaust and block egr that will help the temps. but I think what a few of them are getting at is have you checked your maf sensor. anyway past that I have an auto with bd2.75 egr block and steinbauer and at 110 im sitting about 320 degrees . and from what im reading now is that I should be doing a new intercooler with a new larger intake air scoop which seems to be the bomb
    13 y62 the beast that burbles
  4. The Following User Says Thank You to kevin07 For This Useful Post:
    Patrol-Guy (8th December 2014)
  5. #14
    Dec 2013
    NSW
    Oh yeah I have done the bigger scoop.
  6. #15
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    Needs more boost should see 15psi that'll drop the temp down also dropping a gear driving at about 2500rpm will keep temps down too.i hardly ever used 5th gear on my old zd30 and never used it towing
    Such is the rule of honour.
  7. The Following User Says Thank You to macca86 For This Useful Post:
    Patrol-Guy (9th December 2014)
  8. #16
    Dec 2013
    NSW
    Quote Originally Posted by macca86 View Post
    I'll have to pay closer attention next trip. Maybe it is around 15psi.
  9. #17
    Dec 2013
    NSW
    Anyone recommend someone to fit the EGR plate in the Queanbeyan / Canberra region that knows what they're doing? As I said the last bloke just took it back out cause he couldn't clear the check engine light.
  10. #18
    If you are going to drill a hole in your blanking plate, clamp it well and
    use a slow speed, SS doesn't like fast drilling it will burn and melt your drill.
    Clean up with a 4" grinder, the hole tricks the ECU into thinking the EGR is still working
  11. The Following User Says Thank You to threedogs For This Useful Post:
