nissannewby
In our turbo diesel application with a much denser air charge due to the water injection we actually use less fuel. When you add methanol you can get it cooler again plus get the added power of a highly oxygenated fuel. You don't need a huge amount for good gains and can use boost and egt set points to switch it on and off. In a wagon you could get away with a 30-40l tank no worries. Water/meth injection is the best way to lower intake air temps especially if using pre and post turbo injection. When used with a good intercooler you get a very stable intake air temp.
