Page 41 of 57 FirstFirst ... 3940414243 ... LastLast
Results 401 to 410 of 565
Thread: Parksy's gq
  1. #401
    334 Post(s)
    Quote Originally Posted by Drewboyaus View Post
    Hey mate, what's the procedure for getting the headlining out?
    Sent from my iPhone using Forum Runner
    It's pretty easy to just drop one section Drew. Each of the seems has a tension rod, removing one of the door trims and unfold and you will expose one of these, bend and lift and it will drop out. I would just get a length of Nylon strap or similar and use it as a trace and thread your cables wherever you need it mate.
    Ask AB for one of those rods he had as a flag pole for the Simpson. Perfect for the task. Don't get too carried away with pulling down too much lining.
  2. #402
    334 Post(s)
  3. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    mudnut (30th November 2014), Parksy (30th November 2014)
  4. #403
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Awesome job Parksy, what is the paint you have used on the gearbox mate? POR15 or just a gloss black?
    Looking forward to seeing your roof lining.
    The paint is polyurethane gloss black in a pressure pack. I would have used por15, but once I had to try and remove this paint and it bloody tough, so I'm happy to use it.
  5. #404
    Jan 2013
    Nowra NSW
    5 Post(s)
    And it's in. Bloody nightmare of a job.
    The freshly lubed input shaft makes the clutch really light. Actually feels like a boosted clutch. Very happy with the end result. And glad this job is out of the way.
  6. The Following 3 Users Say Thank You to Parksy For This Useful Post:
    Clunk (12th December 2014), MudRunnerTD (30th November 2014), NissanGQ4.2 (30th November 2014)
  7. #405
    Thomastown, Melbourne
    6 Post(s)
    You shit me Andrew.................
  8. The Following User Says Thank You to Bloodyaussie For This Useful Post:
  9. #406
    Jan 2013
    Nowra NSW
    5 Post(s)
    I shit me Jonathan. It will never be finished. Always have to find something else to do.
  10. The Following User Says Thank You to Parksy For This Useful Post:
    Bloodyaussie (30th November 2014)
  11. #407
    North brissy
    Quote Originally Posted by Bloodyaussie View Post
    That's alright he missed a spot
  12. The Following User Says Thank You to nissannewby For This Useful Post:
  13. #408
    Jan 2013
    Nowra NSW
    5 Post(s)
    I must've missed this conversation?
  14. #409
    Patrol Guru cgm's Avatar
    Jul 2012
    Ballarat
    You've got it sitting up high on stands, so how did you actually lift the gearbox up? Isn't it about 200-250kgs? Obviously didn't do it by hand, but working from under there on the floor, must have been a pain which ever way you did it?
    Thanks, Cameron
    No Patrol now - Just good memories!
  15. The Following User Says Thank You to cgm For This Useful Post:
  16. #410
    Jan 2013
    Nowra NSW
    5 Post(s)
    I used an engine crane through the drivers door going through the transmission tunnel. Used a couple of 10000 pound strops slung around the box. Could tell just how heavy the box was when the strops would creek and moan when moving the crane around.
    Couldn't move it by hand, so used long threads with washers and nuts to draw the box up to the engine. Spent about 3 painful hours getting the angles correct with jacks. Was so happy when the threads actually started to engage. Not an easy job that's for sure. But do-able even if doing it solo.
  17. The Following 3 Users Say Thank You to Parksy For This Useful Post:
    cgm (30th November 2014), Clunk (12th December 2014), MudRunnerTD (30th November 2014)
