Page 12 of 212 FirstFirst ... 1011121314 ... LastLast
Results 111 to 120 of 2116
Thread: Merged - Deleted "Wanted"
  1. #111
    I do.
    Tony
  2. #112
    Jul 2010
    Waterford West Qld
    Have you tried permateks gasket sealant Tony? It's not silicone and very good on water housings.
  3. #113
    Expert 89GQ's Avatar
    Adelaide South Aus.
    Quote Originally Posted by Finly Owner View Post
    do you suggest i use this on the square rubber o ring aswel as the gaskets. The rubber one im'e refering to is number 21045J The square one. cheers
    89 GQ TD 42
  4. #114
    Adelaide South Aus.
    Also what one do you use I went on the site and no. 97 and the new universal blue racing formula mensions waterpumps, housings etc.
    89 GQ TD 42
  5. #115
    For me, I would use silastic on 21045J, it will help hold it in place as you install the housing. Put a bit in the o-ring recess and push the o-ring down into it. For 11072 and 21014 Permatex would be better as Tim suggested. Silastic will still work if that's what you have, but the Permatex is better.
    Tony
    edit; I use blue silastic. The only Permatex I've used (as far as I know there is only one type) is the one that looks like liquid vegemite.
  6. #116
    Jul 2010
    Waterford West Qld
    Quote Originally Posted by YNOT View Post
    Tony
    Yeah that's the one Tony. I was put onto it years ago when I fitted V8 radiator to 6 cyl HZ
  7. #117
    Adelaide South Aus.
    Tony
    Thanks for your help i'll have a look at repco and supadear tommrw, there's that many different ones out there!!!!
    89 GQ TD 42
  8. #118
    Jul 2010
    Waterford West Qld
    Quote Originally Posted by 89GQ View Post
    you'll get more sense from auto barn I reckon.
  9. #119
    Adelaide South Aus.
    Yeh! True, I'll go there. Cheers
    89 GQ TD 42
  10. #120
    Sep 2010
    WANTED: complete set of OEM flares for 95 rx gq patrol black or grey
    As the title says
    pm or email
    trethus@gmail.com
    im in Wagga NSW.
    Cheers.
