Page 1055 of 1057 FirstFirst ... 10531054105510561057 LastLast
Results 10,541 to 10,550 of 10561
  1. #10541
    Aug 2020
    I haven't been on here for a long time, but had a failure coming out of the Wonnangatta Valley a few weeks ago. Started the repair process and is going well.
    The plate is now welded and painter, getting another tower bracket today to weld in and fit the aftermarket Boss brackets a s well.
  2. The Following 6 Users Say Thank You to joe.358win For This Useful Post:
    10G (11th June 2024), MB (12th June 2024), mudnut (11th June 2024), mudski (11th June 2024), PeeBee (11th June 2024), Rossco (11th June 2024)
  3. #10542
    Apr 2021
    Brazil
    What brand/type are those timing belt looking clamps?
  4. The Following 2 Users Say Thank You to BrazilianY60 For This Useful Post:
    Bidja (11th June 2024), MB (12th June 2024)
  5. #10543
    198 Post(s)
    They are a constant tension style clamp, hellishly expensive but once you tighten them to setpoint the clamp remains tight.
  6. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    BrazilianY60 (11th June 2024), MB (12th June 2024)
  7. #10544
    https://www.murraycorp.com/turbo-sea...tension-clamps
  8. The Following 2 Users Say Thank You to MB For This Useful Post:
    BrazilianY60 (12th June 2024), Cremulator (12th June 2024)
  9. #10545
    Hold steady on purchasing Team NP
    Its first two Dyno runs today kept blowing the hose off at the W2A Intercooler outlet side
    Have raced across to Lilydale with two (2) of my original setup Norma T bolt style clamps that handled its first Dyno 2,000km ago.
  10. The Following 2 Users Say Thank You to MB For This Useful Post:
    AB (12th June 2024), Bidja (12th June 2024)
  11. #10546
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    Do use ones personnel preference by all means, used T-Bold clamps with first install of JT top mount cooler 25psi and kept blowing off.
    Changed out to Breeze (USA) HD liner clamps_stainless steel all good. Used these since 2018 on PDI FM and only ever popped one off, when hauling up nth near the doggie Tugger Box. Always carry flex drive and correct hx socket.
    https://www.uniclamp.com.au/products...nt=32628998602
  12. The Following 2 Users Say Thank You to Bidja For This Useful Post:
    AB (12th June 2024), MB (12th June 2024)
  13. #10547
    Legend, Thanks John
  15. #10548
    198 Post(s)
    Thats a surprise I would have thought they would hold, obviously not. Can they be over tensioned and become in-effective also - might be a question for the supplier?
  16. #10549
    198 Post(s)
    This suggests the pressure drop across the w2a is either significant or the clamps are faulty if tensioned correctly. If the new ones hold I mean. A pressure gauge between turbo and w2a would give you some valuable info.
  17. #10550
    Customised guards & snorkel finally fitted up:
    Replacement W2A (my fault) finally arrived and reconfigured the entire intake system, here’s hoping its next 2,000km run in goes a lot more smoothly
    Oh right! i see the clamps you were talking about. Yes that is not what i have used. they look like they should be the ducks guts!! but not??
