Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: TD42 in a GU replacing a RD28
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Haha! You don't. Its only part of the driveline thats different. Maybe i was thinking the brakes as part of the driveline for some reason. Thanks for pointing this out.
    The RD28's use the smaller H233B rear diff though don't they? Not the larger H260 rear.
    Yeah rd28's use the H233B diff. The only drive line difference is the gearbox and rear tail shaft/diff/tcase flanges. The font was identical to my 2001 cab-chassis (both series 1).
  2. #12
    Sep 2022
    Hola como estan tengo una pregunta tengo un patrol y60 con motor rd28t con caja de cambio automatica y quiero cambiar la caja de cambio manual. Y quiero saver si la caja de cambios del zd30 es compatible con el motor rd28t???
  3. #13
    84 Post(s)
    Quote Originally Posted by ssRluis View Post
    The RD28 uses a different gearbox.
