Page 12 of 17 FirstFirst ... 1011121314 ... LastLast
Results 111 to 120 of 166
Thread: Home made tools...
  1. #111
    Thanks Craig Mate
    I’ll try Youtubey searching the rail car mover mechanism, sounds powerful for sure
    EDIT: Is it similar to this one found Craigstar?
    https://youtu.be/7W8c_jMVYAs
    Hey Markie, sorry have not been following this....
    Grab one of these for your Milwalkie drill on hammer only.
    https://www.bunnings.com.au/full-boa...E&gclsrc=aw.ds
    if you have power where you are then easy on an SDSPlus Rotary hammer drill. If not then the Milwalkie Rotary hammer only will work fine. Easy as i reckon. Turn it over face down and it should make easy work of it.
    MB (30th June 2021)
  3. #112
    https://www.wish.com/product/5d68dc3..._BwE&share=web
    Any of these will make light work of it too mate.
    https://www.totaltools.com.au/power-...el-individuals
    Most underpinners use these to hand dig holes in Clay und3er foundations if they cant get a machine in. If you are swinging off a drill all day t will still be an easier day than swinging of a breaker bar for sure. You should be able to move around and use this like a peeler.
  4. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    MB (30th June 2021)
  5. #113
    I have an 11kg SDS Max drill here if you want to go bigger mate, you are welcome to borrow it. I have the clay spade for it too. If you are against a brick wall then anything is better than slugging it out. we can sort out getting it over to you.
    Matty is coming here on the weekend. You are welcome for a beer too
    MB (30th June 2021)
  7. #114
    Thanks Dazman Appreciated
    We did have two cordless hammer drills set up with exactly them years ago in the yard back at base and they did work great with heated curves customised to them
    Unfortunately the trees/logs had to be forklifted up singularly onto steel stands for working back height honest needs and to be honest again my stuffed wrists and even healthier young guns couldn’t do more than an hour or so at a time without real hand muscle/tendon soreness
    Seasonal debarking is absolute key with any contraption and warmer months (summer) is nearly impossible on Ironbark once sapwoods have stopped running, even worse when its been transported out of the coupe back to forklift base and quickly stuck like shiiit to a blanket
  8. The Following 2 Users Say Thank You to MB For This Useful Post:
    MudRunnerTD (30th June 2021), Rossco (1st July 2021)
  9. #115
    Got to try out home made Alaskan style mill over last couple of weeks. . Very happy with how she went, dropped one Yellow Stringy and grabbed anther nice log from next door to mill up some chunky rustic boards with live edge to build a fernery for the folks up at Coota. .
  10. The Following 8 Users Say Thank You to Rossco For This Useful Post:
    BrazilianY60 (7th September 2021), Cremulator (4th July 2021), jay see (15th July 2021), MB (4th July 2021), mudnut (3rd July 2021), MudRunnerTD (4th July 2021), rusty_nail (4th July 2021), Touses (4th July 2021)
  11. #116
    Do this week I've been trying to buy some proper dust extraction for my larger tools(thicknesser and table saw) however I was advised reducing the intake with reduce the suction dramatically and would make the extractor useless(yes some here have suggested the same before too). So tonight I came up with this.
    It's a 44 gallon drum I had laying around, I set an intake and out feed on the lid and jeezus! Works like a charm. Not a spec of dust in the vaccum, and heaps of chips in the drum. Thrilled with the end result.
    Yes my shed is a pigsty at the moment.
  12. The Following 7 Users Say Thank You to rusty_nail For This Useful Post:
    Cremulator (16th July 2021), MB (17th July 2021), mudnut (15th July 2021), MudRunnerTD (6th September 2021), PeeBee (16th July 2021), Rossco (16th July 2021), Touses (16th July 2021)
  13. #117
    Jun 2018
    25 Post(s)
    Does the top come of that drum? Looks like it would be easy to line it with a large bag that you could empty easily
    Top mod!
  14. #118
    Top mod!
    Hi mate, yes the drum lid is removable and I have a liner bag in it. Ended up being a very convenient and complete solution to be laying around.
  15. The Following 2 Users Say Thank You to rusty_nail For This Useful Post:
    Cremulator (16th July 2021), Rossco (16th July 2021)
  16. #119
    Jun 2018
    25 Post(s)
    That is excellent! Nice one
    I love these little hacks that make things easier/better
  17. The Following User Says Thank You to Cremulator For This Useful Post:
    rusty_nail (16th July 2021)
  18. #120
    Jun 2018
    25 Post(s)
    Also that timber has come up nice
  19. The Following User Says Thank You to Cremulator For This Useful Post:
