Page 11 of 17 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 166
Thread: Home made tools...
  1. #101
    Home made tools...
    Thanks Craig Mate
    We’ll give that a try too this week, weather permitting.
  2. #102
    84 Post(s)
    What about push-pull, with two bars attached. One to guide, both applying force to strip the bark?
  3. The Following User Says Thank You to mudnut For This Useful Post:
    MB (28th June 2021)
  4. #103
    Thanks Again Craig Mate
    One of the most noticeable unfortunate things I did initially find was the energy excerpted shoving versus simply dropping and leveraging the old fashioned fast bar spuds. I’ll try anything once but to keep it up for a full 8hrs is hard/impossible for me
    mudnut (28th June 2021)
  6. #104
    Oi MB ,are you smacking the bark with the back of the axe first....we use to ha e to over here,sort of releases the tension between bark wood....back in the day I use to do post n rails,with jarrah of course so this is just a question suggestion
  7. The Following User Says Thank You to Avo For This Useful Post:
    MB (28th June 2021)
  8. #105
    That’s the beauty too of the spud/crow bars Thanks Avo Mate
    When we use them to, raise/drop/raise/drop along to cut the line instead of chainsawing a line it shock/pops the bark up for approximately 25% of its top circumference, once top opened we just lever and peel off like a bark canoe. The photos above weren’t very elegant as was butchered testing all sorts of angles, walloping, scraping exhaustion
  9. #106
    A little Red Ironbark lucky example of using my boots a few months ago with an 8kg too heavy all day crowbar to firstly cut the top popping line:
    Shocking definitely works AVO Mate
    Disclaimer: Only when the sapwood is seasonally running, Summertime no chance of this
  10. #107
    84 Post(s)
    What about a spur that spikes the log and gives you traction. Drawing is not to scale.
    After the initial start where you get enough meat for the spike to bite, it should let you steer and use leverage instead of brute force.
    Somewhat the same concept as they use to move rail cars.
  11. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    MB (29th June 2021), rusty_nail (29th June 2021)
  12. #108
    Home made tools...
    Thanks Craig Mate
    I’ll try Youtubey searching the rail car mover mechanism, sounds powerful for sure
    EDIT: Is it similar to this one found Craigstar?
    https://youtu.be/7W8c_jMVYAs
  13. #109
    84 Post(s)
    Yeah, but using the leverage from pushing down, not lifting. Looking at it, I think it will just try and bust out the top of the bark. Anyway just a thought.
  14. The Following User Says Thank You to mudnut For This Useful Post:
    MB (30th June 2021)
  15. #110
    I think you'd need the spiked pivot lever at a much more acute angle (and spring-loaded for rebound), the thrust lever foot operated and the cutting head fixed (not pivoted) to optimise forward and slightly downward thrust for this to work.
    IMHO of course
  16. The Following 2 Users Say Thank You to Plasnart For This Useful Post:
    MB (30th June 2021), mudnut (29th June 2021)
