Page 45 of 51 FirstFirst ... 4344454647 ... LastLast
Results 441 to 450 of 502
Thread: Fuel consumption / economy report
  1. #441
    82 Post(s)
    From Ballan to Christmas hills and a bit of city driving then to a service centre on the freeway. 255 km for 37 litres. 14.5 km/l. Not too bad with two adults and fully loaded with camping gear.
  2. #442
    Beginner Convert's Avatar
    Dec 2019
    First test untouched truck, 93, 4.2 non turbo, neglected, 540,000 km, Automatic, Shorty.
    20L/ 100km
    Then new injectors, new rocker assembly, oils, filters, Manual conversion, 31 inch tires,
    Best was when nursed along at 80-90km/hr on long trip mostly flat 10.6 L/100km
    Worst was 12.5/ 100km pushing it along in the high 2000rpm range on a hot day.
    Average Highway driving on hot day 95-100km/hr 11.8L/100km
    Today I filled it at 600km with the needle halfway between the 1/4 and empty (71L)
    I reckon in cold climates they will go better but these sorts of numbers are ok with me.
  3. #443
    82 Post(s)
    I kid you not. 13.098 l/100ks, with the new engine, running tuned to 95 RON petrol. It was just me with all the seats fitted and the winch loaded with rope instead of steel cables and a full tank of juice. It was mainly highway but with plenty of hills to give it a squirt. 52.6 ks at 6.89 l.
    PeeBee (11th June 2020)
  5. #444
    2001 GU TD42T. No IC. Engine and cooling system stock as a rock. 33" tyres. Pulled a 2.8 tonne trailer yesterday 220km from sea level up to approx 520m above sea level. Max 4th gear (manual), mostly around 80km/h at around 2000rpm. Some steep climbs back to 3rd, 50km/h at 2500rpm. Burnt 33 litres at 15.3l per hundred uphill. Pretty happy with that.
  6. The Following 2 Users Say Thank You to Plasnart For This Useful Post:
    MB (2nd January 2021), mudnut (30th December 2020)
  7. #445
    GQ TD42 NYE NSW 2020.
    Scored 46.2L per 10kms crossing/idling the border bridge back VIC home
  8. The Following 4 Users Say Thank You to MB For This Useful Post:
    Cremulator (2nd January 2021), mudnut (2nd January 2021), PeeBee (2nd January 2021), Plasnart (2nd January 2021)
  9. #446
    476 Post(s)
    I've never been the one to worry about/ look at fuel consumption, on any of my cars. I just get in and drive it and when it needs fuel, it gets it. Lol.
    Rossco (5th January 2021)
  11. #447
    176 Post(s)
    Since we left Broome in June '19 . Lots of corrugated/bull dusty roads plus a reasonable amount of low range driving where consumption rose to almost 21 litres per 100. Mostly towing the Tvan with a vehicle & van combined weight of around 5 tonne. We take it pretty easy. Average around 80kph on flat bitumen, with occasional 'squirts' above 110kph when needed. Rarely exceed 3000rpm, or 450 deg.C EGT. Without the Tvan & with water tanks empty best has been just under 12l per 100km , but 13 to 14 litres per 100km is more usual. Average 90ph to 100kph when not towing.
  12. #448
    Haha same with looking at fuel prices, never really bother, drive till empty, fill up, keep driv'n. . .
  13. The Following User Says Thank You to Rossco For This Useful Post:
    mudski (5th January 2021)
  14. #449
    Dec 2019
    Western Sydney, NSW.
    My Patrol is on a Novated Lease with $300 P/Month Fuel Allowance, so Fuel Economy is something I watch a little. If my Torque App is correct, I get about 20Lt/100klm, much higher then Nissan's stated 13Lt/100klm . . . but I recognise my Patrol is not a stripped down off the production line Patrol either.
    I've wonder a thew times if it's worth putting My Ute into a Diesel Tune Workshop just to see if it can be retuned to get better Fuel Economy.
    Grant
    Penrith Region
    Sydney NSW.
  15. #450
    My very first beloved 2000 GU TD42T DX Leafy work ute gained an extra 50km per 80L rear OEM tank average and a guesstimated 10% more lugging power simply by having a (custom mod in the day) 3” exhaust fitted and tuned to suit by Andy @ Dieseltec Lilydale Victoria
    EDIT: Wasn’t my (customer modification request) Andy was assisting local blokes and I jumped on board too, never looked back financially work wise!
