Page 40 of 98 FirstFirst ... 3839404142 ... LastLast
Results 391 to 400 of 972
  1. #391
    Yeah Enzed made me an adapter for about $5. While I waited.
    mudski (29th June 2020)
  3. #392
    The issue is Daz. The thread in the lower hsg is M12. The probe is 1/8 npt. To get the probe in far enough where it was. Won’t work with M12 thread. There’s just not enough meat in the adapter to make it work.
    Post stat I think, is the best option. It’s actual temp right after the stat. So it’s pretty much real time water temps.
    Time will tell anyway.
    MudRunnerTD (29th June 2020)
  5. #393
    Jun 2018
    25 Post(s)
    Thats how far out the sensor was sitting on mine. The sensor is no way near the water flow as it was. Even when its flush on the housing the tip of the sensor is barely in. On a side note. Can I buy that plug from you? I need this to plug up my housing.
    Edit : And are you coming to Licola? If not. Why?
    Sure thing, you can have that old plug. I'll give it to you. I don't throw anything out
    I'd love to come to Licola, the wife isn't so keen so I might try to sneak an overnight in by myself
  6. The Following User Says Thank You to Cremulator For This Useful Post:
    mudski (30th June 2020)
  7. #394
    Thanks. Im pretty sure I have my old plug, somewhere. I just need to sift through the boxes of crap I have. If I can't find it I'll let you know.
    It would be great for you to come to Licola. We all have an absolute blast when we are there.
  8. #395
    Jun 2018
    25 Post(s)
  9. #396
    Got the bar back from the sand blasters and powder coaters yesterday. Getting thereAttachment 81286
    Attachment 81287
    Came up good except for where I did my hole patch up work. It’s quite obvious, but it looks a heap better now. So I’m not too concerned. Yet.
    I also had all the special washers, and one of the adjuster stops zinc plated. The other stop would not come out so it stayed in the bar.
    Attachment 81289
    hey mate, how much did it cost for the powder coating of the bullbar? did they snad blast it first? I have a rear Kaymar bar that i am thinking of getting done before selling it, trying to figure out if it will be worth it to make a little more on the sale.
  10. #397
    $480 for the sand blasting and powdercoating. I wouldn't bother if your selling it.
    MudRunnerTD (30th June 2020)
  12. #398
    Mudski's High Warn High Mount Rebuild into an ARB GU Bar
    Not much getting done with the bar and winch. I have so much else to do as well.
    I used the last of my oil filter stock today from when I sold the business.
    Chucked in a new fuel filter while I was at it.
    Removed the rocker cover as it was leaking a tap. Then decided to sand it back and I will paint it. Yes I am a bit eccentric sometimes. Lol
    Then. There’s the interior...
    I need to get a new head unit. And run wires through to the engine bay for the winch. Then put the dash back together.
  13. The Following 2 Users Say Thank You to mudski For This Useful Post:
    MudRunnerTD (3rd July 2020), Rossco (3rd July 2020)
  14. #399
    Hey @mudski Do you not have a Members Ride thread already? dd you want me to rename this thread and move it to the Members ride section for you? seems to have morphed well beyond a simple himount and bar thread. You look busy by the way. Looking good mate.
  15. #400
    I did Darren but the site I was using to upload the pics shut down, or something happened, can't remember to be honest, and all the pics wouldn't work. I got the shits with it so I just left it. If you can rename it, Mudski's GU Build thread, or something or something like that, and move it that would be great! Thanks Darren.
  16. The Following 2 Users Say Thank You to mudski For This Useful Post:
