Page 871 of 1057 FirstFirst ... 869870871872873 ... LastLast
Results 8,701 to 8,710 of 10566
  1. #8701
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    Said good bye to my Patrol for the last time
  2. The Following User Says Thank You to Yeti's Beast For This Useful Post:
    GQtdauto (3rd November 2018)
  3. #8702
    Aug 2016
    Jimboomba
    4 Post(s)
    And replaced it with this
  4. The Following 2 Users Say Thank You to Yeti's Beast For This Useful Post:
    Clunk (3rd November 2018), jay see (4th November 2018)
  5. #8703
    Well kind of. Grab the line that goes into the little tube that comes out the side of the reservoir. Take this off and place into a bucket. Disconnect fuel solenoid as the pump will pump quicker than you can fill if the engine is running. Crank it a little and top up fluid with fresh stuff until its clean out the return line.
    Well I done that, oil looks like it has gone through coming out the return line red as the new stuff. So why am I getting this leak of dirty oil coming from the threaded shaft on top of the box.
  6. #8704
    Thought I'd fit the radius arm spacers today ...
    Lucky I started on the passenger side.
    Spacer in. And axle fouls on the Panhard rod.
    F*** a duck.
    How did you go.... I haven't fitted spacers so not much help from me.
  7. #8705
    Does anybody know what's under this plate. Can't seem to find it, not even in the manual.
    Thinking that there has to be a o ring or something.
  8. #8706
    Your thinking is correct. Looking at this drawing you should not have power steering fluid at that adjuster. Looks like the box needs a reseal. The oil will be dirty from the grease in there hence the grease nipple. 20181104_101547.png
  9. The Following User Says Thank You to nissannewby For This Useful Post:
  10. #8707
    Thanks mate, I couldn't find a diagram like that. should be able to pop up the plate a replace the o ring yeah?
    Will keep updating progress.
  11. #8708
    Should be possible. You will have to remove that nut to do so. Measure the thread poking out the top before removing so you can put it back where it was. I'm not sure that o-ring will resolve your leak though.
  12. The Following User Says Thank You to nissannewby For This Useful Post:
    jay see (6th November 2018)
  13. #8709
    So I need to remove the thread as well?
  14. #8710
    Well that thread screws down. Problem is the whole box needs to come out.
    Might put it back together and just regease it for now....
