Page 870 of 1057 FirstFirst ... 868869870871872 ... LastLast
Results 8,691 to 8,700 of 10564
  1. #8691
    OK. First check was p/s level and yes it's low. Then clean around, started and looked. Seeping out of the top.
    Just bad timing or would the dirty bath have anything to do with it.
    How to fix. Just tighten or has a seal gone.
  2. #8692
    176 Post(s)
    Wombat forest 1 - 0 @jay see
  3. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    jay see (2nd November 2018), Rossco (2nd November 2018)
  4. #8693
    Nah, mate 3-0
    Everytime I go there.
    Hydronic locked a surf.
    Custom dents on the passenger side.
    And now this.
    Anyone tried one of those stop leaks?
  5. #8694
    176 Post(s)
    Thought I'd fit the radius arm spacers today ...
    Lucky I started on the passenger side.
    Spacer in. And axle fouls on the Panhard rod.
    F*** a duck.
    Looking at the power steering can someone tell me which is the return line top or bottom?
    The front coolers are stone cold after a drive, I want to flush the system then try this stuff apparently it's meant to work.
  7. #8696
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Will be watching this because mine is leaking badly but think I need the rebuild kit .
  8. The Following User Says Thank You to GQtdauto For This Useful Post:
    jay see (3rd November 2018)
  9. #8697
    Low pressure will be the line that goes out to the cooler.
  10. The Following User Says Thank You to nissannewby For This Useful Post:
  11. #8698
    Will keep you posted.
    This is my daily, so if a band aid fix will work, that's good enough for now.
  12. #8699
    So if I get that line and block it off before it goes to the reservoir, then start engine and continuously top up the reservoir unti it comes clean out of the same line.
    Sorry if it doesn't make sense, it's a bit hard to explain, but I think I've got it right in my head.
  13. #8700
    Well kind of. Grab the line that goes into the little tube that comes out the side of the reservoir. Take this off and place into a bucket. Disconnect fuel solenoid as the pump will pump quicker than you can fill if the engine is running. Crank it a little and top up fluid with fresh stuff until its clean out the return line.
  14. The Following User Says Thank You to nissannewby For This Useful Post:
