Results 1 to 7 of 7
Thread: Nord Lock Washers
    178 Post(s)
    Nord Lock Washers
    Has anyone used these babies? I only learned of their existence yesterday.
    I was at the bolt shop yesterday & wanting something better than nyloc nuts to secure the canopy on my Patrol. Nylocs have been ok, but have needed regular retightening, as have Nylocs + spring washers. Bolt shop said next step up was 'cone' nuts, but they didn't have any in the size/thread to suit the bolts I had (M12 metric fine/1.25 pitch/ high tensile 10.9) but mentioned the Nord Lock washers as being a step up from cone nuts. They had a demo, tighten a wing nut up to just finger tight & then try to undo. The effort needed to undo was quite impressive, so much so I bought 10 washers at $3.50 each! Have fitted all the new bolts today (replacing a mish mash of different bolts requiring several different spanners!) together with the Nord Lock washers & nylocs - fingers crossed.
    https://www.hobson.com.au/page/nord-...el-washers.php
  2. The Following 3 Users Say Thank You to Cuppa For This Useful Post:
    Bigcol (6th June 2018), Bloggsy (6th June 2018), MudRunnerTD (6th June 2018)
    Awesome Cuppa, i have had an ongoing issue with the after market rear sway bar link undoing and loosing the pin. Drives me bonkers. Nyloc just undoes itself over time and its gone. I will be chasing some of these up for sure. Thanks for posting it here.
    178 Post(s)
  5. The Following 3 Users Say Thank You to Cuppa For This Useful Post:
    Bigcol (6th June 2018), Maxhead (6th June 2018), MudRunnerTD (6th June 2018)
    Cheers Cuppa, i have actually seen that Vid before but was great to watch to again.
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Sorta, the fastener company I use 2 work for sold the exact same brand yep a step up for sure
    177 Post(s)
    I think these are used on all our EWP's at work, where secure hydraulic ram's are bolted etc... So they must be rated well.
  9. The Following User Says Thank You to Hodge For This Useful Post:
  10. #7
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    great bit of kit they are
