Page 93 of 136 FirstFirst ... 9192939495 ... LastLast
Results 921 to 930 of 1356
Thread: All Things Chev
  1. #921
    483 Post(s)
    Happy Days blokes, truly thank you both! Mrs MB has finally collected our PO Box :-)
    @PeeBee mate bargain price and I really can now see their internal fin efficiency design exactly like your sketch thanks mate!
    PeeBee (9th January 2018)
  3. #922
    Yep, they work alright! Now get it installed unlike the originals that sat on the shelf staring at you.
  4. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (10th January 2018)
  5. #923
    483 Post(s)
    Will do my best mate although winter coming again soon will buy me another 9 months, lol :-)
    As a quick fix for the high mount cooler drain back to sump issue do you blokes believe simply plumbing the lines from engine up highest on the firewall could in theory work? Picture below of some ‘orange airline’ scraps placed to help explain the line path/trap I’m theorising about?
    Does appear from a side view on the GU that this firewall height is above the new Philstar wicked cooler bullbar mount height!
  6. #924
    483 Post(s)
    Best modification yet @PeeBee mate!
    (Very productive night here, lol :-) )
    Double Dozen Goggie’s back there now baking in all this leftover space :-) !
  7. The Following 2 Users Say Thank You to MB For This Useful Post:
    GQtdauto (13th January 2018), PeeBee (11th January 2018)
  8. #925
    Mark, putting a u bend in the supply line and return line will work. Alternately you could put a pair of simple check valves in the line facing the same way, being the same flow direction. They are closed when no flow/pressure.Talk to Pirtek about that as they offered it to me, however I have simply gone with the 2L overfill situation after confirming with BD that it would be fine.
    MB (11th January 2018)
  10. #926
    483 Post(s)
    @PeeBee mate, which way again?
    Sideways?
    Longways?
    Time to get busy :-) !
  11. The Following User Says Thank You to MB For This Useful Post:
    Rossco (13th January 2018)
  12. #927
    Mark, I don't know if the air is thin up there in Xmas Hills, but I will explain it again, S L o W L y.
    The Light bar comes off and is sent express post to me. The oil cooler is mounted where the light bar sits now. You will need a herbaceous planter box in front of the cooler to disguise it from the Vicroads inspectors. The herbs will improve the heat transfer when you are stationary as they will shade the cooler - let me know if you need assistance selecting the varieties. The herbs will allow you to provide fresh garnishes with your camp roasts.
    I can only assume you have been misled by those other two Xmas Hills gremlins as i thought this was explained very clearly.
  13. The Following 4 Users Say Thank You to PeeBee For This Useful Post:
    AB (21st January 2018), GQtdauto (13th January 2018), MB (13th January 2018), Rossco (13th January 2018)
  14. #928
    Sideways... but cut a hole in the Bonnet and put an ARE Scoop in with the Cooler on top and screw a Light Bar to the Cooler... with a Mack Bulldog on top of that again
  15. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    GQtdauto (13th January 2018), MB (13th January 2018), PeeBee (13th January 2018)
  16. #929
    ... and if you hook up a herbaceous planter box to your coolant tank you could even have a Grow Operation happening
    Light, Heat and Nutrients... Tick, Tick and Tick!
  17. The Following User Says Thank You to the evil twin For This Useful Post:
  18. #930
    483 Post(s)
    Cheers blokes, got it sorted now I think ;-)
