Results 1 to 10 of 54
Thread: Towing a Patrol using a Patrol
Threaded View
    You can buy a complete "A" frame set with all the attachments, braking set up and rear light harness from the larger caravan and motor home dealers. They are not cheap - but they comply to AS and will work first time.
    True... esp the not cheap part... and the vehicle that will be under tow needs some modifications as well (unless you are only off roading of course).
    If you go unbraked the Tug must be over 3 times the tare of the vehicle being flat towed which is why some nomads opt for a trailer rather than an A frame setup unless you opt for a heap of extra bucks to enable to the vehicle under tow braking
    http://www.transport.wa.gov.au/media...rameTowing.pdf
  2. The Following User Says Thank You to the evil twin For This Useful Post:
    dom14 (23rd September 2017)
