A bit more shop'n today. Got sum new weather strips for the doors (the inner & outer bits that the windows slide through), ordered a bonnet sound dampner thingy and an aftermarket glow plug timer. .
Timer looks really good, keen to see how it works but hopefully helps with cold starts as mine is a bit different with the 12mm. Has an after glow which pulses for 2 sec on off for as long as you as you set it. Also doesn't glow at all if you just crank it which is nice i reckon, and hooks up to the factory dash lamp so will look like factory now ☺
