Results 1 to 4 of 4
Thread: Will a GQ front LOKKA fit in my new 04 GU?
    Feb 2014
    Hi,
    Anyone knows if a GQ front LOKKA fit in my new 04 GU?
    Or can i just swap the whole front axel? Or is the Gu axel/brakes etc better?
    Thx
    Yes it will go straight in. If the Diff Ratios are the same then you can just swap the whole centre, if they are different the Lokka will go straight into the GU Centre.
    The GU Diff is a far better assembly than a GQ with bigger CVs and bigger Brakes and Wider to suit the GU Body.
    Feb 2014
    Thx that helps a lot
    Feb 2011
    Shed
    45 Post(s)
    What he said ^^^^
