Page 367 of 570 FirstFirst ... 365366367368369 ... LastLast
Results 3,661 to 3,670 of 5698
  1. #3661
    That was the bloke i spoke to to gey my stickers (Steve). He was great, very good service sent out a sticker kit for free ☺ . .
    Same here, posted from the U.S. for free. Even threw in a couple of big ones for the shed fridge.
  2. #3662
    We email about once every 2 months, Steve's just brought a new well 69 chev pick up 4wd.
  3. The Following User Says Thank You to threedogs For This Useful Post:
    GQtdauto (15th April 2017)
  4. #3663
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    I brought one of the wireless remotes years ago but was told to avoid it
    especially if a tricky situation arises, I have a winch isolation switch
    inside on the centre facia next to a winch in/out switch. Yet to wire it all up.
    My son is an auto elec but thats not going to happen now eh GRrrrrrrrrr
    In a perfect world a 3 battery set up would be nice with 2 x crankers for the winch
    and a DC for the AUX. I had a 3 battery system in my other 4x4 but had no winch
    just two lockers ARB and a Pro-locker up front best set up ever. Not sure what I want to do in the future
    E-lockers are expensive IMO. I have an on board tank and motor again yet to be wired. Plus need to rip
    the 3 gallon tank out of the other 4x4,,,so many jobs,,, How often do you come to town????
    Like most things TD they get better with age , the newer wireless winch controls are the ducks nuts imo.
  5. #3664
    Insulation blanket for the exhaust from SuperCheap - 25% off, so at $35/10m, worth the effort. I was surprised to see its base is volcanic ash and ground up lava flow - interesting, but your hands get a bit of residue during the process of fitting it.
  6. #3665
    Quote Originally Posted by PBBIZ2 View Post
    Do you have a turbo beanie yet, I love them keeps the heat where it should be inside.
    protects the Aux battery as well
  7. #3666
    Don't have a twurbo TD, thanks for bringing that up.
  8. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    GQtdauto (15th April 2017), threedogs (21st April 2017)
  9. #3667
    I reckon they work a treat, you can put your hand on the turbo after say a hwy run.
    Plus my aux battery is a wet cell 115 trojan [more bang for buck] and I've found I
    top it up less now.lol
    PeeBee (21st April 2017)
  11. #3668
    Adventurist stevemc181's Avatar
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    I bought a Scangauge II as my Torque Pro app doesn't seem to work as well with the Patrol as it did with the Pajero?
    I also bought a bluetooth dongle for my Victron BMV-702 battery monitor. This will basically send all of my BMV-702 data to my tablet or phone. (God I love technology!) This means I can move the ugly BMV-702 gauge out of the pillar pod and put it down the back somewhere, hmm this also means I now have a spare spot for another redarc gauge in the pillar pod. I am thinking Trans and engine temp gauge will go nicely in there.
    2016 GU Legend Edition: 3505Kg GVM Upgrade and Stuff!
  12. #3669
    177 Post(s)
    Quote Originally Posted by stevemc181 View Post
    Do you have the G52-BET model of the Redarc gauge? That has the optional temp display. Maybe wire up the water sensor to that. Providing you do have that model. I cant remember which one you ended up getting.
  13. The Following User Says Thank You to Hodge For This Useful Post:
    stevemc181 (21st April 2017)
  14. #3670
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    I went for the model with EGT and digital boost only (G52-EB) as I preferred the wider 270⁰ sweep of the needle. I'll have water temp on the scan gauge so will probably go for engine block temp and auto trans temp gauge (Not sure where the sensor goes on the GU for this, but I think it is on the trans oil cooler?). I've also got a low level coolant alarm on the way, but prefer to know the block temp also.
  15. The Following User Says Thank You to stevemc181 For This Useful Post:
    Hodge (21st April 2017)
