I have the scan gauge which has a delayed reading so its not really accurate.
The Redarc gauge is going in early next week, boost, EGT and an extra port for auto temp.
Dawes valve ect in a week or so, so will get the re-map done after this has been set.
The smell is defiantly running in the exhaust paint ect.
It is fumy with more noticeable diesel fumes, think the re-map will fix that.
How much is a re-map and where is a good place to go near Springvale?
Scan gauge went from 14/15 LPH to 33 as a read out. This is not true when I fill up.
It use to read around 24 for first drive of the day and drop to around 14/15-16 after 10 min.
Now it reads anywhere from 30+ to 70 and settles out to 17 after 10 min on the same root.
