Results 1 to 7 of 7
Thread: Exhaust then tune?
    Expert rusty00's Avatar
    Jun 2015
    South Eastern VIC
    Exhaust then tune?
    Just fitted the Beau desert 2.75 exhaust and have found that it is now not burning like it did with the original exhaust.
    It is a bit fumy and smelly.
    It also is giving small puffs of black smoke and sooty at the tail pipe.
    Will a remap or dyno tune fix this and is it normal for this to happen?
    I was wondering also is it to do with the smaller muffler and one less muffler from original.
    2012 GU8
    It may be burning paint etc as it heats up, Go the remap every time.
    Have you fitted a boost gauge yet or Scan gauge??
  3. The Following User Says Thank You to threedogs For This Useful Post:
    rusty00 (23rd February 2017)
    177 Post(s)
    I've now had 3 Beaudesert exhausts. Every time there was burning off for a few days. Paint , or gaskets or whatever coating they use ...
    A good tune or chip after exhaust is always good as it can bring everything else in line with the better exhaust flow now.
  5. The Following User Says Thank You to Hodge For This Useful Post:
    Jun 2015
    South Eastern VIC
    I have the scan gauge which has a delayed reading so its not really accurate.
    The Redarc gauge is going in early next week, boost, EGT and an extra port for auto temp.
    Dawes valve ect in a week or so, so will get the re-map done after this has been set.
    The smell is defiantly running in the exhaust paint ect.
    It is fumy with more noticeable diesel fumes, think the re-map will fix that.
    How much is a re-map and where is a good place to go near Springvale?
    Scan gauge went from 14/15 LPH to 33 as a read out. This is not true when I fill up.
    It use to read around 24 for first drive of the day and drop to around 14/15-16 after 10 min.
    Now it reads anywhere from 30+ to 70 and settles out to 17 after 10 min on the same root.
    2012 GU8
    Mar 2013
    NE Melbourne
    If you think the diesel fumes are more noticeable then a remap won't fix it. The oem exhaust has a catalytic converter in it. Does the new exhaust have one? If not then that's probably the reason. You can get hi flow after market cats but not sure how affective they are compared to the oem cats.
  8. The Following User Says Thank You to Rock Trol For This Useful Post:
    rusty00 (26th February 2017)
  9. #6
    Jun 2015
    South Eastern VIC
    Quote Originally Posted by Rock Trol View Post
    It has the cat in the exhaust, might be a smaller one.
    2012 GU8
  10. #7
    Has your exhaust settled down yet??
    is your boost gauge fitted yet that may tell some stories??
