Results 1 to 10 of 1356
Thread: All Things Chev
Threaded View
  1. #10
    Quote Originally Posted by rainsey View Post
    On my Brunswick installed 6.5 the interface between the Intercooler and the inlet manifold is a cone looking tube with a kink in the end to accomodate the intercooler hose.
    I am toying with putting in a larger intercooler but the height of this inlet is too high.
    Does anyone know of a inlet connector that is lower than that which Brunswick use and will permit not only a larger intercooler but also a fan to be used?
    Kindest regards
    Rainsey
    Sent from my iPad using Tapatalk HD
    Rainsey can you drop a photo of what you have? My engine is NA so totally different setup. My years in piping config may lead to a simple solution.
    rainsey (27th January 2017)
