Page 32 of 77 FirstFirst ... 3031323334 ... LastLast
Results 311 to 320 of 762
Thread: Jay see 1997 GU build up
  1. #311
    John sorry haven't been much help. On Holidays and been out of phone reception camping..... I concur with ben-e-boys pic. The centre connector should be an earth connection. You can run the small earth wire on bottom of winch motor to any metal contact point anywhere or even run it to the middle solenoid connector then onto an earthing point from there, plenty of ways to skin that cat. The split in the power in/out in the diagram, as ben-e mentioned, is the in/out switch which you can mount in the dash somewhere for in-cab controls. I used a momentary double pole double throw (DPDT) toggle switch for mine. To wire it to your existing controller plug you need to figure out which wire in the plug corresponds. Eg.
    No apologies mate.
    Holidays and camping lucky bugger.
    I'll sort it out, one way or another.
    Thanks for the info, will take it onboard.
  2. #312
    Please pardon my ignorance as like John, electricals are not my strong point.
    Whats the advantage of this Albright solendoid? What can it do over say the solenoid thats on my current winch?.
  3. #313
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Depends on the solenoids you currently have. The albright are a great sealed low maintenance solenoid that is reliable. The old style warn 4 solenoid pack in mine were unreliable and it needed 2 for in and 2 for out. Only required 1 solenoid to be on the fritz and it was done. They were expensive to replace as well so upgrading to a newer style solenoid made sense.
  4. The Following User Says Thank You to sooty_10 For This Useful Post:
    mudski (29th November 2016)
  5. #314
    22 Post(s)
    They are a solid state relay, they have no moving parts to fail, no contacts to pit or burn out. The down side to SSR's is they don't 'play up' as such. They work and then they don't.
    96 GQ coil/Cab
    08 G6eT
  6. The Following User Says Thank You to Ben-e-boy For This Useful Post:
  7. #315
    Thanks. Makes more sense now. So no use in me putting one on my winch since theres nothing wrong with what I have. Apart from severe lack of use this year.
  8. #316
    Bendigo
    7 Post(s)
    As long as you run your winch in and out occasionally and give it a once over or inspection once in a while to ensure it is all kosher for when you actually need it, all will be good.
    Nothing worse then thinking ahh it should work and then actually get stuck and it doesn't or has issues. I usually go into the bush just behind my place and wind the rope out to a tree and then winch the truck up a small incline re-tensioning neatly the rope after each use or every couple of months. I got caught out a few times with the dodgy solenoids before so am a bit paranoid now. Haha
  9. The Following 2 Users Say Thank You to sooty_10 For This Useful Post:
    MB (29th November 2016), mudski (30th November 2016)
  10. #317
    There's some things I can do, some things I can't and then there's the ones if I fark up it's going to cost me time and money. I know my limits.
    The light bulb came on re: the solenoid and I think the problem was, I was looking at Ben's pic wanting to wire it up to my handheld controller, not a separate switch as in that pic... I think.. Anyway sorted now.
    The patrols in getting some goodies fitted and I got them to wire it up. Saves me blowing up a perfectly good solenoid or anything else for that matter.
    May be able to get away for a few hours next weekend anyone keen?
    Almost like me at Cobaw..
  11. #318
    Depends on if our house sells this Saturday and we have bought another before then.
  12. #319
    Of course it will.
    Good luck.
  13. The Following User Says Thank You to jay see For This Useful Post:
  14. #320
    sounds more water friendly as well, a good upgrade imo
    What brand winch do you run??
