Page 31 of 75 FirstFirst ... 2930313233 ... LastLast
Results 301 to 310 of 748
Thread: Jay see 1997 GU build up
  1. #301
    Why is there a temporary wire hanging off the earth.
    This is how it should be wired. The pic you posted earlier with the power in and power out description on the coils is incorrect. Probably more misleading.
    I dont understand why you have a temp cable hanging off the earth.
    Attachment 70036
    The temp wire is to get power for the switch? That's what I got from the pic.
    You say that the earlier pic is incorrect re power in/out. How why?
    What is the right way?
    If it all worked I was going to slice that temp wire into the black wire.
    If someone local has wired one in a bit of a look see would help here. @sooty_10 can you share done light on this mate.
    Edit.
    Just noticed that you added a pic. I have seen this and will try to work it out using that.
    Electrical is not for me, but I try.
    Thanks @Ben-e-boy
  2. #302
    Where I'm stuck.
    1.
    3 wires coming out of the handheld. In, out and another
    2..
    Thin wire (earth I think) out if bottom if winch.
    Might have to leave it for another day..
  3. #303
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Where I'm stuck.
    1.
    2..
    If you didn't live miles away I'd say I'd pop around and give you a hand
    Sent from my E6653 using Tapatalk
    Lucus30's 1999 GU ST TB45E
  4. The Following User Says Thank You to lucus30 For This Useful Post:
    jay see (27th November 2016)
  5. #304
    22 Post(s)
    Where I'm stuck.
    1.
    3 wires coming out of the handheld. In, out and another the "another" wire is power to the hand held switch
    2..
    Thin wire (earth I think) out if bottom if winch. that is earth. It is from the centre pin of the solenoid
    96 GQ coil/Cab
    08 G6eT
  6. The Following User Says Thank You to Ben-e-boy For This Useful Post:
  7. #305
    The power wire I ran to the centre blade, but the pic shows a neg to battery?the two in/and go the the + on the, do the wires get split, two to the terminals and then to the + ?
    Can that earth be mounted anywhere there's metal.
    I'm confused, and frustrated...
    And my head hurts.
  8. #306
    I'm going to join @Clunk at the happy thread.
  9. The Following User Says Thank You to jay see For This Useful Post:
    Clunk (27th November 2016)
  10. #307
    Thanks for the help @Ben-e-boy
  11. #308
    22 Post(s)
    The power wire I ran to the centre blade, but the pic shows a neg to battery? the two in/and go the the + on the, do the wires get split, two to the terminals and then to the +? where it 'splits' as you say is your hand held controller switch
    Can that earth be mounted anywhere there's metal.you can mount the earth wire from the centre pin to the earth connection on the motor
    And my head hurts.
    The diagram I posted is correct.
    96 GQ coil/Cab
    08 G6eT
  12. The Following User Says Thank You to Ben-e-boy For This Useful Post:
  13. #309
    Thanks I'm going to use that one when I get back to it. It's only a couple of wires and I really should be able to do this.
    I've packed it up for today.
    This weekend wasn't very productive.
    Tried to complete 2 jobs neither were successful.
    Oh well the porks looking good at least.
  14. #310
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    John sorry haven't been much help. On Holidays and been out of phone reception camping..... I concur with ben-e-boys pic. The centre connector should be an earth connection. You can run the small earth wire on bottom of winch motor to any metal contact point anywhere or even run it to the middle solenoid connector then onto an earthing point from there, plenty of ways to skin that cat. The split in the power in/out in the diagram, as ben-e mentioned, is the in/out switch which you can mount in the dash somewhere for in-cab controls. I used a momentary double pole double throw (DPDT) toggle switch for mine. To wire it to your existing controller plug you need to figure out which wire in the plug corresponds. Eg.
