I do.
The EGR system has a cooler which cools the exhaust gas before entering the cooling system. Removing this cooler will take some load off your cooling system as well. The pipe around the back can be removed with the turbo in place its just a little tricky.
As I have mentioned to you on the phone if someone has altered the static timing of your pump this wont be helping any of your causes.
