Page 25 of 75 FirstFirst ... 2324252627 ... LastLast
Results 241 to 250 of 747
Thread: Jay see 1997 GU build up
  1. #241
    Thanks James.
    Better get it sorted.
  2. #242
    Been looking at how to secure the spare tyre on the factory holder.
    One option that I've came across is to mount 3 wheel studs and then fit a lock nut.
    Wreckers won't knock out 3 studs and repco want $10 each stud with nut.
    I know $30 isn't alot, but has anyone got any that they don't need?
  3. #243
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Hey is there any reason why you're not / can't use the factory holder and bolt combo or have I missed something.,..
  4. The Following User Says Thank You to Bacho86 For This Useful Post:
    jay see (9th November 2016)
  5. #244
    476 Post(s)
    Yeah the factory holder uses three nuts with a stud as part of the nut. I then use a padlock to secure it on.
  7. #245
    It's a 10mm tread with the hex head nut. Thinking of drilling a hole through the flat of the nut and using a padlock. Is this where your got the lock Mark?
  8. #246
    476 Post(s)
    Kinda lost on where your at. Do you need to mount the wheel and lock it? Or just lock it?
    Heres mine.
  10. #247
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    The albright doesn't need to go in the standard solenoid box, and most likely won't fit without modification. You can simply rerun new cable and wires to put it where ever you want or use the current cabling and put it where it fits reaches. Most folks rerun it and put it up in engine bay out of the mud.
    I used existing cabling and mounted it behind bullbar near original solenoid box. Refitted the warn solenoid box in bullbar otherwise I'd have a hole in top of my bar. I may rewire it all and put it up higher in engine bay one day when i find motivation.
    I haven't seen an albright which wouldn't work on any of the 4x4 12v winches I've seen so yours will be no different. This is what a genuine albright looks like and will work with your winch. .
    They are usually around $170 on ebay. Then there are albright 'style' which are copies and would most likely also work, just cheaper.
    I'm still trying to work out where to mount mine in the engine bay it's bigger than I thought
    Sent from my E6653 using Tapatalk
    Lucus30's 1999 GU ST TB45E
  11. The Following User Says Thank You to lucus30 For This Useful Post:
  12. #248
    Heres mine.
    Just lock it.
    My holder is the factory one with the outer been plastic. Can't go through the centre
    After a couple different locks and a oversized hole on the top closest to the free hole I still can't get a lock on.
  13. #249
    It doesn't have to go in the bay, but yeah probably better.
  14. #250
    Sep 2013
    16 Post(s)
    Yeah I know my current one isnt. But I want to put this one in
  15. The Following User Says Thank You to lucus30 For This Useful Post:
