Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Winch maintenance request
    Cuppa (1st September 2016)
  3. #12
    Yea mate they are easy as to pull apart..
    And yea I think 3 years is a good time to service.
    I pulled mine after 2 years and found a small trace of water / moisture in my runva.
    Nothing critical, wiped out and re greased and put back together..
    They are very easy.
    178 Post(s)
    Thanks Darren, I replied on that thread. As I said I will have to check when I'm able, but suspect that getting the winch on & off may be the hard part.
  5. #14
    Can I see a "Cuppa's winch party" coming together?
    Winnie (1st September 2016)
  7. #15
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    Cuppa, I know bugger all about winches BUT we can learn together. As long as you're not in a rush.
    Jack
    2024 Isuzu MUX
  8. #16
    178 Post(s)
    Thanks Jack, moral support welcome & certainly in no hurry. Plenty of other stuff on the 'to do list' first!
    As it is though, curiosity got the better of me & I made the effort to go & have a look at the access to the winch a short time ago. (This involved sticking a mirror on the end of a stick as laying under the car could see me stuck down there at present). It appears I was indeed informed incorrectly by whoever it was (& who's word I took) about the bullbar needing to be removed. There is a plate underneath the bullbar held on by 4 (or possibly 6) bolts which I expect is what Darren & Sooty have referred to as the 'splash guard'. That being so the job of removal just got a whole lot easier.
    Darren, Sooty, would I be correct that the winch is attached to the vehicle via bolts into threaded holes in the 'feet' of the winch?
  9. #17
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    The winch is often attached by the 4 bolts into the actual bar. The fairlead bolts are often 2 of the 4 then the winch will simply fall down. It is heavy so needs support.
  10. #18
    They are very easy.
    would it be worth pressurizing the winch for future water/river crossings
    Im hopeing to do mine in the near future, just need a needle valve to
    regulate the pressure needed.
  11. #19
    Na..
    For the little I do lol..
    The gearbox was horizontal so I'm suspecting it's leaked threw that seal as it was quite dry.
    New seal and lever is vertical now.
    See how it looks in a year or 2.
