Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: What about dash cams>???
    Just thinking who's running a dash cam and how often,
    I have one but dont use it daily ,,,maybe I should
    I do use it if going away
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    yep use it all the time. the ones that only record when they sense a impact are next to useless in a patrol. so one that records all the time then you just pull the card after the accident would be my pick.
    177 Post(s)
    Mines on everytime car is running running on 5 minute loop. It also has bump sensor, if car is bumped while being OFF, it instantly begins recording.
    Patrol God Stropp's Avatar
    38 Post(s)
    yes mine records all the time and over writes, has bump sensor and movement sensor for instant record
  5. #5
    Perth WA
    63 Post(s)
    Same as Stroppy, some of the things you see Perth drivers do are just unbelievable
  6. #6
    Yeah mine is similar , will turn on if someone is near, with night vision as well
    great feature I reckon ,,,,,,Cost $60 about 4 years ago
  7. #7
    Quote Originally Posted by Doggy View Post
    Same as Stroppy
    Same here, but I have given up. After three units they all had different problems.
    Sent from my XT1068 using Tapatalk
  8. #8
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    So what units do people recommend? HD? Can you actually read number plates in the videos? Do you use them also for 4x4 track recording?
  9. #9
    Dec 2015
    WA
    5 Post(s)
    After several no fault accidents we have been looking at them for work cars. Our IT guy has found some that record front & rear with optional side views, GPS position & speed, OBD conditions (to see if the cars are being thrashed), they automatically upload to the server when they come into WiFi range at work.
    They are quite a bit more expensive but this is probably how corporate vehicles will have to go.
    Graham
  10. #10
    Can't recommend a good one, but a HD is only good if you play it back on a HD screen which these days most are.
    I've played it back on the HD flat screen at home and it looks brilliant.
    Think there's a Facebook page on 4x4 dash cams...
    https://youtu.be/woHYUy4Uv8k
    Here is one from the last Dargo trip.
  11. The Following User Says Thank You to jay see For This Useful Post:
    sooty_10 (27th August 2016)
