Quote Originally Posted by GeeYou8 View Post
Two stroke oil is ashless, so it does not form solid particulate matter when burnt.
Have been following this discussion for a while & have done a bit of research. Found an interesting article from a fuel testing company about adding 2 stroke oil to diesel.
From the article
"The results of the study support a view that the practice of dosing diesel with 2-stroke oil is surprisingly ineffective in terms of lubricity and cetane improvements. Engine performance, fuel consumption and emissions were also unchanged; however the use of 2-stroke oil in diesel is potentially harmful to modern diesel injection equipment. Trace amounts of zinc, an element which is found in most 2-stroke oils, are well known to cause injector nozzle fouling and the study measured high levels of injector fouling when the test engine was running on diesel dosed with 2-stroke oil."
The full articale can be found here http://www.fuelexpert.co.za/2-stroke...ical-study.php
Wonder how many "Grenade" issues might have been caused by engines using 2 stroke running lean & burning holes in pistons due to injector fouling?
