I don't know what a 12mm pump is, are they normally noisy? Is it worn therefore makes more noise?
Does using an additive hide a problem, having something fail in the centre not knowing it was an issue is the reason for the question.
The other side of the coin is, a problem starts to appear then adding an additive could get you out of there.
